Is it possible to keep the Koodo number running while travelling outside Canada (Not USA)? Add on options to receive calls and texts only?
  • Updated 2 years ago
Is it possible to keep the Koodo number running while travelling outside Canada (Not USA)? What are the add on options to receive calls and texts only? Feedback appreciated.
Photo of Sagar Ashara
Sagar Ashara
Posted 2 years ago
Photo of Mathieu
Mathieu, Mobile Master
Hi Sagar,
How much usage are you planning to do while away? You can take a look at the international roaming add-ons available that are listed here.
Sagar Ashara
Well, I won't be making any calls unless it's urgent but i need to keep track of all calls and messages I receive while I am outside Canada. Not sure which add-on to choose.
Photo of Tiz
Tiz
  • 4,604 Points 4k badge 2x thumb
Connection with internet is required also for Skype, Fongo, etc. Nowadays it is quite easy to find hotspots at restaurants, bars, libraries, tourist offices, and so on.
Photo of David
David, Mobile Master
  • 93,400 Points 50k badge 2x thumb
I thought Whatsapp required all users be using the Whatsapp App? Is it a direct replacement for SMS clients?
Photo of David
Photo of Tiz
Tiz
Yes, sorry, it requires also the other party to be on Whatsapp. I use it quite often and I got too excited.
Photo of Goran
Goran, Mobile Master
  • 96,868 Points 50k badge 2x thumb
What you can use is a voip app recommended to me called TextNow. It's like Fongo only texts are included whereas Fongo charges I believe 2 dollars a month for unlimited texting. That way you can keep in touch when around wifi or even if the prepaid data packages are good where you are, run it 24/7.
