Is it possible to have two phone numbers which go to the same phone?
I'm using my personal number and cell phone for my job. I'd love to know if I could separate the two and not have to hand out my personal number associated with my business. Maybe even getting a toll free number? Thanks so much!
Photo of Darci Riemer
Darci Riemer
  • 84 Points 75 badge 2x thumb
Photo of Matthew Gosché
Matthew Gosché
  • 478 Points 250 badge 2x thumb
The easiest solution would be to call forward one phone to the other. There is no way for that to happen on the Koodo aide, however there are many apps that can be an 'internet' number or you could purchase and unlocked duo Sim phone from the uk! Good luck!
Photo of Daniel Gunn
Daniel Gunn
  • 19,800 Points 10k badge 2x thumb
Hi Darci,
Koodo doesn't offer a service like that unfortunately, the only company that can offer two separate numbers on one phone is Rogers. I've posted a link for you to have a look at.
http://www.rogers.com/web/content/wir...,
Hope that helps answer your question :)
Photo of Dennis
Dennis, Mobile Master
Kinda.
You will need 2 sim cards and a dual sim phone. Some chinese phones have this function. Koodo does not sell these phones.
Or you can just forward all your calls from one phone to the other
Matthew Gosché
Is that how this site works? This is the 3rd time you've said exactly what I said but reworded a little bit? Sorry I'm new
Photo of Dennis
Sorry just been taking me longer to type. Watching the Apple live stream at the same time.
As you noticed, posts do not refresh as you type
Daniel Gunn
It happens to me too Matthew, usually what happens is when someone is responding to a question you normally don't see the other replies until you've posted your comment and you can get the same answer from different people on one question.
Hope that helps clear some confusion. :)
Daniel Gunn
As you can see that just happened to me again lol
Photo of Dennis
And looking back at your posts Matthew, this is the first time it has happened with me
Darci Riemer
Thank you all for your quick replies! Super helpful
Photo of Some random Mobile Master
Some random Mobile Master, Mobile Master
  • 39,554 Points 20k badge 2x thumb
Hey Darci!
Just get yourself a number (or port one) from VoIP.ms.
Create a forwarding rule for that number, calls will be forwarded to the number of your choice (in this case, your cellphone).
VoIP.ms charges 0.005$/minute outgoing, and 0.01$/minute incoming.
They also have tollfree numbers, at a slight price increase.
Hope it helps!
