Is it possible to block outgoing 411 calls on the wireless home phone?
  • Updated 7 months ago
Photo of Steven Geller
Steven Geller
Posted 7 months ago
Photo of Sophia
Sophia, Mobile Master
No, I don't think so Steven... is there a reason why you need this blocked?
Steven Geller
Relative using the WHP used to have this as a free service with Bell, and forgets that it's $2.50 /call with Koodo. Any suggestions appreciated!
Photo of Goran
Goran, Mobile Master
  • 96,868 Points 50k badge 2x thumb
You'll just have to tell your relative to not call 411 then I guess. As far as I know 411 especially cannot be blocked.
Steven Geller
Thx, unfortunately that won't work, they have memory problems
Photo of Goran
Perhaps a note by the phone "411 costs 2.50 ask x to search for something you" or something like that?
Steven Geller
Tried that with no success. Any idea if this device might work in Canada & with the WHP device? https://www.hqtelecom.com/outgoingcal...
Photo of Goran
The only thing you can really block is calling internationally by not adding the pay-per-use international long distance feature. That's just phones: whatever you dial in, it will try to connect.
