Is it possible
  • Updated 1 year ago
I am permanently locked out of my SIM card I need to buy a new one once I do is it possible to transfer all my talk time and data and contacts from my locked SIM card to my new one
Photo of Lindsay Morrison
Lindsay Morrison
  • 80 Points 75 badge 2x thumb
Posted 1 year ago
Lindsay Morrison
Please help
Photo of Goran
Goran, Mobile Master
  • 96,970 Points 50k badge 2x thumb
Talk time and data isn't kept on your Sim card. If you're referring to your plan, it transfers seamlessly when you get a new Sim card and swap to it. As for contacts, any that are stored on your Sim card are gone if you cannot access it anymore. Whatever google backs up, however, is easily swapped from device to device.
Photo of Dennis
Dennis, Mobile Master
  • 196,006 Points 100k badge 2x thumb
You can do this sim card swap via self serve.  you just need to enter the new sim card number to switch your line over to the new sim card
Photo of Robert
Robert, Mobile Master
  • 106,774 Points 100k badge 2x thumb
Hello Lindsay,
How did you lock your SIM card? Can't you input the PUK code to unlock it (you need to call Koodo for the PUK code).
