Is HD Audio now supported?
  • Updated 2 years ago
I just used my Koodo iPhone 6s to call my wife's Koodo iPhone 5s and the call quality definitely sounded like HD audio, which was a big surprise.  Is VoLTE now officially supported, and does it work down to the iPhone 5 models as well?
Thanks Koodo!
Photo of Chris Boyce
Chris Boyce
Posted 2 years ago
Photo of Ivan
Ivan, Mobile Master
Where are you located? Telus has VoLTE in AB/BC, so Koodo may have it there as well. No VoLTE in the rest of the country yet.
Chris Boyce
I'm in Peterborough, Ontario... not exactly a large metropolis.  Her voice was definitely coming through in HD - way better fidelity than normal... I would compare it to FaceTime audio from a Macbook Pro.
Photo of Ivan
Ivan, Mobile Master
Chris Boyce
Ah, that's what I was wondering.  So the question is, what changed.  If it's simply wide-band audio (better codec) I'm wondering if Koodo recently implemented support for it or if a recent iOS update maybe triggered something.  Whatever it is, I like it.
Photo of Ivan
Ivan, Mobile Master
It's anyone's guess without official word as to where the change occurred but I'm glad to hear you're happy with it.
