is calling barrie ontario long distance from newmarket ontario
  • Updated 2 years ago
I just want to know if I call Barrie Ontario from my office in Newmarket Ontario will I billed long distance charges? if not do i need to just dial the area code plus the phone number or should I put a 1+area code + phone number?
Photo of mathew j
mathew j
  • 134 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Ivan
Ivan, Mobile Master
The easiest method to use is to place the call without using 1 when dialing. If you get the warning before the call is place, then you know it's long distance. You can hang up when you hear the message and you won't be charged.
Are you certain you don't have nationwide minutes? Most plans do.
Photo of mathew j
mathew j
My plan says unlimited Canada-Wide Calling so why am I going to be dinged long distance? I have the unlimited texting and calling package for $53 + the cost of the phone at $15 per month. I made an attempt but was informed that I should stay on the line for my call to be completed and long distance charges may apply. I hung up just in case there is a long distance charge.
Photo of Ivan
Ivan, Mobile Master
The automated long-distance warning system doesn't know your plan. It only informs people that it's a long distance call and that they "may" be billed. If you've got Canada-wide calling, you won't get billed.
Photo of mathew j
mathew j
Yes my plan says unlimited Canada-Wide Calliing. I guess that explains that.
Photo of Tiz
Tiz
  • 4,604 Points 4k badge 2x thumb
I get the same message all the time I make a long distance calls but no charges are applied. Computers like to joke sometimes.
Photo of Ivan
Ivan, Mobile Master
The message does say "long distance charges may be applied" not "will be applied. Never applies to me but I can see its usefulness to those with local minutes (while such plans still exist).
Photo of grampad
grampad
  • 1,876 Points 1k badge 2x thumb
If the 'long distance charges' message bothers you simply add 1 as a prefix to the area code+ number and you won't hear it. Just make sure you check your usage occasionally to avoid overages. The after 5 pm and weekends free is a great perk of the plan.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Nobody's talking about being bothered by the message grampad, everyone's talking about it being useful because the question was to find out if it's long distance from place A to place B
