Is an unlocked Note 4 (SM-N910W8) compatible with Koodo?
  • Updated 7 months ago
I'm looking at purchasing an unlocked Note 4 (SM-N910W8) device and wanted to ensure it was compatible with Koodo's network before purchasing.
Thank you.
Photo of Jonathan
Jonathan
  • 80 Points 75 badge 2x thumb
Posted 7 months ago
Photo of Dinh
Dinh, Mobile Master
  • 42,346 Points 20k badge 2x thumb
The SM-N910W8 is a North America model, supporting 850/1900 3G and LTE bands 4,7,5,2. Then it is highly compatible with Koodo network.
Photo of Goran
Goran, Mobile Master
  • 97,868 Points 50k badge 2x thumb
For future reference you can use willmyphonework.net to see if just about any phone will work with just about any carrier around the world. However, if there comes a time that you can't find the phone on the site, just know the bands named above you're looking for 1700/2100 mhz or 2600mhz for LTE, that being band 4 and 7/38.
Photo of Jonathan
Jonathan
Thanks for the quick and helpful answers Azure123 and Goran.
Didn't know about willmyphonework.net. Will use that next time. Thanks!
