iPhone text requires data plan if not connect Wi-Fi?
Elaborate on if/when a data plan is required? After discussing text messaging problems with the Koodo help desk, I was advised text messaging requires a data plan (for iPhone) when not connected to Wi-Fi.
Supposedly this is a recent change by Apple? Text messages are routed through the Apple server and hence Internet connection is required?
Photo of A4away
A4away
  • 112 Points 100 badge 2x thumb
Photo of Daniel Kim
Daniel Kim, Mobile Master
sms doesn't require data or wifi. BUT imessage does require either a data or wifi connection, you don't necessarily need a data plan, even pay per use data works.
Photo of Dennis
Dennis, Mobile Master
  • 196,890 Points 100k badge 2x thumb
If you are just text messaging and not wanting to use iMessage, just turn off imessage in your settings. Then no data/wifi will be required
Photo of Ahmad
Ahmad
^Which would be in Settings -> Messages
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,766 Points 100k badge 2x thumb
Or activate the 'send as sms' setting on the same page.
