iPhone 5 CDMA+GSM Verizon on Koodo network ?
HELP* Will this iPhone work on Koodo network? It's a CDMA + GSM Verizon unlocked iPhone. I've been told be some that those don't work apparently on the Koodo network, however, I believe these ones can use both sim and cdma so it should work?
http://www.ebay.ca/itm/Apple-iPhone-5...
Photo of Luke Antony Gram
Luke Antony Gram
Photo of Ahmad
Ahmad
As long as the specifications listed in the listing are correct, then yes it will work on Koodo as long as it's unlocked and has a sim card tray/slot.
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
It just wont work with LTE.
Photo of Ahmad
Ahmad
True. I don't ever use LTE so I never remember :P Too much of a battery drain when HSPA is just as good, IMO
Luke Antony Gram
Is it because Koodo doesn't support LTE on their HSPA network? I checked and there is LTE coverage in Kelowna based on Koodo's website. How come the phone wont function with LTE?
Photo of Jorden
AT&T Verizon and Sprint use different LTE frequencies in the states. I can't remember if the 5C/S are more universal but the iPhone 5 was unique to the big three carriers when it came to LTE. In Canada we're the same as AT&T
