iPhone 4 VPN Settings
Can someone please guide me in setting up an VPN for my iPhone 4 (iOS 6.1.3)?
Photo of Warren Tang
Warren Tang
  • 176 Points 100 badge 2x thumb
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,538 Points 100k badge 2x thumb
Here's a link to a video showing exactly how just substitute your VPN provider for the one used in the video. https://www.youtube.com/watch?v=7Jelp...
Photo of Chris Petersens
Chris Petersens
Here is another VPN app that I use. Very easy to use, inexpensive. I watch US and Brittish Netflix with it, which you can't have access to from Canada unless you have one of these.
Warren Tang
Thanks guys!
Another question though: I've noticed that I cannot receive MMS (picture texts) when I'm connected via Wifi but as soon as I switch to 3G network, I can. Why is this? Is there a way to be able to receive picture texts via Wifi?
MMS has to come through your data connection it can't be done through wifi on any stock messaging app on any phone. You might be able to find an app that you can send picture messages through wifi I'm not sure on iPhones.
Keep in mind that even though it uses data to send MMS if you have unlimited texting you will not be charged for the data used to send that MMS, though any apps open at the time of turning on your data connection to send an MMS will indeed use chargeable data so make sure nothing is running in the background when you go to send the MMS if possible.
Photo of Elhum
Elhum
  • 60 Points
here is a quick guide for VPN set up on iPhone4.
Tap on Settings Icon > Tap General > Tap Network > Tap VPN.
>> Now find an option of “Add VPN Configuration”.
Select a protocol lets suppose, PPTP, > add VPN configuration being provided by VPN Provider. > Description is simply the Name that you want to give to your VPN, Name it what you like. > Now Server name its also provided by the VPN service . like “connect.something.com”.
>> by the Same way your Account Name and Password will also be given by your VPN Service, >after these 3 fields, Set your RSA Secure ID to Off, >
> let encryption to Auto. > Set, “Send All Traffic” to “ON” its done save all configurations now just revisit the settings where you will see a new VPN bar turning it ON will enable your vpn service, if all this does not work for you you can visit http://goo.gl/NdG9H thanks
