Iphone 3G dropped connection with all setting enabled
  • Doesn't Need an Answer
My iphone 3G connection dropped 2 days ago - all settings are on to allow 3G but there is not icon at the top. The phone connects to wifi. Does this have something to do with my plan or is there something wrong with my phone?
Photo of Rebecca Roberts
Rebecca Roberts
  • confused
Photo of Myke
Myke
what type of connection are you referring to?
Photo of Daniel Kim
Daniel Kim, Mobile Master
it could be that the areas you are in aren't covered by koodo or it could be the phone since the iphone 3g is a pretty old device.
Try rebooting your phone.
Photo of rikkster
rikkster, Mobile Master
  • 66,966 Points 50k badge 2x thumb
Try turning off your iPhone, open the SIM tray, then close the SIM tray. Power up your iPhone and see if the 3G icon returns.
Photo of Dennis
Dennis, Mobile Master
Go to Settings > General > Reset > Reset Network Settings
Note that you will lose your saved WIFI passwords and any saved networks
