iPhone won’t connect to US network
  • Updated 2 weeks ago
iPhone 5s on prepaid Koodo, I have bought the US roaming add ons. We are now in Florida and my phone continues to say ‘no service.’ I have pulled the SIM, restarted empty, and restarted again with the SIM and no change. I went to carrier setting so and switched to manual, and I can choose AT&T from that list, but it won’t connect - still shows ‘no service.’ Any ideas?
Photo of Farrell Clark
Farrell Clark
  • 142 Points 100 badge 2x thumb
Posted 2 weeks ago
Photo of Dinh
Dinh, Mobile Master
  • 33,324 Points 20k badge 2x thumb
Hi Farrell,
Did it work before?
I would try to reset the network settings of the phone also. Goto Settings --> General --> Reset--> reset network settings.
Farrell Clark
This is the first time we’ve travelled to the States with Koodo, so we haven’t had a chance to try it before.
I did the network settings reset and same thing - I can manually choose a network like AT&T, but it won’t actually connect; still says no service.
Farrell Clark
The US roaming plans show up in my account, yes.
Photo of Dinh
Dinh, Mobile Master
  • 31,564 Points 20k badge 2x thumb
@Farrell: I would suggest you send a message to Koodo facebook/twitter and ask them to check on your account.
Also, if possible, can you pop the SIM into another phone and see if it could connect..
Photo of Dennis
Dennis, Mobile Master
  • 186,190 Points 100k badge 2x thumb
When you say US roaming plan, you mean the US roaming boosters?
Is your base plan active?
Farrell Clark
Yes, sorry, they roaming boosters. And yes, base plan is active.
Photo of Dennis
Ok then Dinh's previous post seems to be the only options left
