Iphone SE - iMessage and Texting without DATA
  • Updated 1 year ago
I have an Iphone SE, talk and text only plan.  Do I need to leave Cellular Data turned ON?  I want to receive messages thru imessage and regular text.  Currently I am not receiving texts at all.  Any help would be appreciated.
Photo of Jan
Jan
Posted 1 year ago
Photo of Dennis
Dennis, Mobile Master
  • 195,954 Points 100k badge 2x thumb
If you want imessage, you need to be connected to wifi or cellular data.  note if your plan does not have data, then it will cost you data
Photo of Robert
Robert, Mobile Master
  • 106,754 Points 100k badge 2x thumb
Hello Jan
As Dennis mentioned, you should leave it on. But because you have no data it won't work. Just stable iMessage. It will be less complicated that way.
Photo of Mayumi
Mayumi, Mobile Master
  • 115,026 Points 100k badge 2x thumb
Even if you have no data plan, you can still access to mobile data with Pay-per-use-rate. (Unless you ahve a data block on the account level)
So, if s/he leave data on and send/receive iMessage and/or update some apps in background, then s/he will get get data charge.
