iPhone 5s power issues!
  • Updated 10 months ago
My iPhone 5s started powering off and restarting on its own at random now is in a perpetual state of apple symbol on the screen trying to restart I think?
Photo of jrockstar
jrockstar
  • 90 Points 75 badge 2x thumb
Posted 10 months ago
Photo of Dinh
Dinh, Mobile Master
  • 41,784 Points 20k badge 2x thumb
Have you tried to update the software? and restored the iPhone? From the description, it might be a hardware issue, not mobile network. I would seek helps from Apple, they might be able to diagnose that problem.
Photo of Goran
Goran, Mobile Master
  • 97,308 Points 50k badge 2x thumb
Have you tried pressing and holding both the home and sleep / wake button for 10 seconds? Does the force restart fix it? If not, trying to go into DFU mode. You do the same for Wp seconds only instead of releasing both button, release only the sleep button and keep holding the home button for 5 seconds. These times are exact. Too long or too short and it won't work right. It should become a black screen. Plug it in to a computer with iTunes. See what can be done about diagnosing it through iTunes. Maybe it'll need to have the os reinstalled.
Photo of David
David, Mobile Master
  • 93,614 Points 50k badge 2x thumb
I’m guessing “Wp seconds” is a mis-key meaning 20 seconds.
Photo of Goran
Not sure actually. It was late / early. 10 seconds again. Thanks for the catch.
