Iphone 5c not allowing Data to work
  • 2
  • Updated 2 years ago
So i just upgraded to a 750mb data plan from previously having none. im using an ihpone 5c and when i turn on cellular data i'm not getting any sign of 3g or lte (also i cant do anything data would allow you to)
Photo of Ed Clow
Ed Clow
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
  • 2
Photo of Goran
Goran, Mobile Master
  • 90,800 Points 50k badge 2x thumb
Toggle network or airplane mode on/off. If that doesn't work, restart your phone. If that doesn't work, take your Sim card in and out. It should work then.
Photo of Adrian VanGameren
Adrian VanGameren
  • 62 Points
I have the same problem on my iphone 5c. I got 1gB of data today and I'm not able to access it. I've done all the things Goran has suggested already.
Photo of Goran
If data is turned on and you've done the above an nothing, check to see if you have data block active on your account.
Photo of Daniel
Daniel, Employee
  • 5,712 Points 5k badge 2x thumb
Hi Ed! Were you able to activate the data on your iPhone thanks to the above suggestions? Keep us updated :)
