iphone 4 wont connect to wifi
  • Updated 2 years ago
iPhone 4 won't connect to wifi anywhere now....just happened. I restarted the network settings, turned it off & on, turned it on airplaine mode.... The software is up to date.
Photo of Vivienne Bosworth
Vivienne Bosworth
Posted 2 years ago
Photo of Mathieu
Mathieu, Mobile Master
  • 60,828 Points 50k badge 2x thumb
Hi vivienne,
What error messages are you receiving when you attempt to connect to a wireless network?
Photo of Mathieu
Turn on airplane mode, and shut the phone down. Remove the SIM card as well, let it sit for about 5 minutes. After that, put the sim card back in, turn on the phone and then turn airplane mode off and see if you can see networks again.
If not, then I would suggest performing a factory reset on the phone.
Vivienne Bosworth
Thank you.  Did all that and it still isn't working. My other apple devices and others' phones are able to connect to the various Wi-FI networks.
Photo of David
David, Mobile Master
  • 88,942 Points 50k badge 2x thumb
What happens if you choose 'Other' and type in the credentials for your router (i.e. both the SSID and the password)?
Photo of David
Photo of Mathieu
You did a full system restore? Meaning you have deleted everything and reinstalled iOS on it?
