Intl. roam add on - what do i need in the "on" position to avoid addede costs beyond daily $10.00 - Cell data, Enable 3G, Data Roaming, or?
  • Updated 4 months ago
for international roaming add on, what do i need to have in the "on" position to allow the $10.00 a day add on to function correctly so as not to incur any additional costs beyond the daily $10.00 a day charge i.e. Cellular data on or off ? Enable 3G on or off ? Data Roaming on or off ? anything else ?
Photo of Glen
Glen
Posted 4 months ago
Photo of Dennis
Dennis, Mobile Master
  • 187,544 Points 100k badge 2x thumb
Login to self serve
Go to the menu and select mobile services.
Under Easy Roam click details and food the instructions there
Photo of Glen
Glen
very helpful, thank you both !
Photo of Dennis
So the above will enable your easy roam. Which will mean you can use your regular plan like you would in Canada.
If you don't have data to use, then turn off your data on your phone.
3g can remain on
Photo of J
J
  • 230 Points 100 badge 2x thumb
Also make sure to have the Roaming data on in the settings of your phone
