international plan
  • Idea
  • Implemented
Is there an international voice plan for Koodo?
Photo of Ross Rygh
Ross Rygh
Photo of Jonathan I
Jonathan I, Mobile Master
I think Koodo has recently added roaming packages for Mexico and another country that I can't recall right now but that's it, besides the U.S. I'm not saying it won't work; you can enable international voice roaming as long as you're not on spending limit program, but the rates start at $1.50 or $2.50/min and .60/text plus $5/MB for data.
You're better off unlocking your phone (unless it's a Nexus device) and using a local provider in the country you're visiting. The rates will probably be cheaper.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 137,092 Points 100k badge 2x thumb
It's actually Mexico and the Carribean (which covers all Carribean countries except the Bahamas). The U.S. Virgin Islands are covered by the U.S. package and not the Carribean one though.
