International long distance saver
  • Updated 10 months ago
If you go over your "daytime minutes", do your calls to the U.S. (with the international long distance saver plan) go from .05 to .35 per minute?
Photo of Tammy Rizzi
Tammy Rizzi
Photo of Myke
Myke
You will still be charged $0.05/minute if you go over your airtime minutes with the LDsaver.
Photo of Sophia
Sophia, Mobile Master
  • 141,528 Points 100k badge 2x thumb
Good question Tammy! Myke, I was wondering, is the LD saver separate from the "normal" minute allowance? Say you have 200 minutes with a plan and you call to the US for 50 minutes, do you still have 200 minutes or does it go down to 150? What happens with the 201th minute, is that $0.05 or $0.55?
Just being curious :)
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,892 Points 100k badge 2x thumb
You will be charged airtime plus applicable long distance charges.
Photo of Khaleila
Khaleila
  • 4,102 Points 4k badge 2x thumb
Hey Tammy, Just to confirm, you'll be charged airtime ($0.05/mins for the Ld Saver) and long distance ($0.35 or $0.50 depending on your rate plan).
________________________
Photo of Laura Smail
Laura Smail
  • 190 Points 100 badge 2x thumb
Can someone explain to me what ling distant saver is. Can not find any info on it. Thanks
Photo of Mathieu
Mathieu, Mobile Master
  • 60,828 Points 50k badge 2x thumb
Hi Laura,
Bassically it gives you a more favorable rate when calling internationally. So if you call the united states without the add-on, you will pay 0.50$ per minute. If you have the add-on, your rate will be 0.05$ per minute. It's great if you call occasionally, and don't need the unlimited calling. You would need to call to the US for more than 233 minutes to make the 10$ unlimited add-on worth-it.
Laura Smail
Thank you, so much Mathieu. Very appreciated.
Photo of Peter Saunders
Peter Saunders
Does the long distance saver count for calls that you receive or only for calls that you send?
International long distance charges do not apply to incoming calls.
Peter Saunders
Thanks!
