International incoming calls?
  • Updated 2 years ago
Hi,
I have a 45$ monthly plan with unlimited incoming calls. But, do "incoming calls" mean international incoming calls?
Photo of Greg Doudrich
Greg Doudrich
Photo of Mayumi
Mayumi, Mobile Master
  • 115,066 Points 100k badge 2x thumb
Yes. You can receive international incoming calls without charges, as long as your phone is in Canada.
Photo of Mo D.
Mo D.
  • 17,268 Points 10k badge 2x thumb
Wow Mayumi. You are up early!! :)
Photo of Tia McGraff
Tia McGraff
  • 60 Points
Hi we have the $60 per month regarding. Koodo plan. Have added on texting for uk. While here in uk with my phone will I be charged extra for incoming calls from canada
Photo of Daniel
Daniel, Employee
  • 5,714 Points 5k badge 2x thumb
Hi Tia! Yes, you will be charged for any incoming calls if you answer the phone. You can always not answer and send them a text :) Hope that helps.
Photo of Nada
Nada
Is it also valid if I add the unlimited incoming calls option to my current plan, which charges for incoming calls? I think that should be the case, but still wanted to be sure before paying for it.
Photo of Nada
Nada
Thanks Chad. And if I pay for the unlimited incoming call add on today, I will have that option (domestic + international incoming) for 1 month starting as of today, right?
It's pro rated, it renews on your billing cycle until you remove it. It'll be active today after you add it.
When you get the bill you'll see a charge from today to your bill date, then another charge to pay for the add on for the next month.
Photo of Nada
Nada
Great. Thanks.
Photo of Nada
Nada
I do have a last question. Is it the "Minutes Local Income Unlimited" ($10.00) add on? I was confused by the "local" part.
As long as you're on a plan that says Canada Wide as part of its name, you never need to worry about what's local because Canada becomes local.
