International text roaming not working in France
  • Updated 8 months ago
I'm in France right now with my koodo lg g5. Before I left I added the international voice roaming addon thru self serve. I also added the international text addon by texting TXT15 to 7626. I received the confirmation on this before I left. Upon getting to France I received the boilerplate roaming message from koodo "welcome to France...".
However when I got to send a text all the messaging apps I've tried result in some sort of time out message. I've tried texting numerous numbers all with same result.
I've played with selecting various networks, various apps, rebooted, removed sim card,... All to no avail.
Help!!
Photo of Tom Roe
Tom Roe
  • 90 Points 75 badge 2x thumb
Posted 8 months ago
Photo of BobTheElectrician
BobTheElectrician
  • 59,756 Points 50k badge 2x thumb
Are you using international dialing conventions?
https://countrycode.org/how-to-call
Photo of Robert
Robert, Mobile Master
  • 102,352 Points 100k badge 2x thumb
Hello Tom,
When you try to send the message, do you have a connection to the network?
Like Bob suggested try dialing + 1 - area code - 10 digit phone number and tell us if it works.
Photo of Bernard
Bernard, Official Rep
  • 74,024 Points 50k badge 2x thumb
Tom, pls try to set your phone on airplane mode than back. Sometimes that helps with network resetting. Let us know if it worked.
Photo of Tom Roe
Tom Roe
I had played with the number format, prior to Bob's suggestion, with no success.
I just noticed that international data roaming has been added to my account, presumably by a koodo rep. I hadn't added it myself as I didn't want to accidentally rack up data charges. However, whether coincidentally or not, text now works.
Thanks for your help.
Photo of Bernard
  • 74,012 Points 50k badge 2x thumb
Hmmm...you shouldn't need the data roaming part and I can remove it for you if you are concerned Tom. I wonder if you still be able to continue to text. Do you want me to take off the data roaming feature?
Photo of Allan
Allan, Mobile Master
  • 53,688 Points 50k badge 2x thumb
Was the Pay-Per-Use Intl Long Distance add-on added as well? That may have been the one tbat allowed you to text.
Photo of Tom Roe
Tom Roe
Yes. It appears the Pay-Per-Use Intl Long Distance add-on was added as well. Not what I would call intuitively obvious but it's working.
Bernard- you can leave the data addon as is. It's working and I'm not wanting to spend anymore time on it. Vacation and all:). Thanks.
BobTheElectrician
  • 59,704 Points 50k badge 2x thumb
You can probably disable data roaming in your phone settings if that becomes a concern without affecting voice or text services.
