International Roaming Self Serve, when disabled, will it roam in the States?
  • Updated 2 months ago
I have voice and data international roaming disabled on my self serve... but want to know if it is for just overseas, or the States or both?  ...and if it works properly without having to worry about getting charged.
Photo of Tim Skully
Tim Skully
  • 320 Points 250 badge 2x thumb
Posted 2 months ago
Photo of Mats
Mats
  • 24,654 Points 20k badge 2x thumb
It is just for overseas.
What do you mean if it works properly without being charged? If you use your phone while roaming you will be charged. It will be pay per use rates unless you have easy roam on your account.
https://www.koodomobile.com/help/easy...
Photo of Tim Skully
Tim Skully
Bad wording. I read somewhere that it would leak data and they would be charged for the small amount it leaked. Maybe that was for the setting on the phone. I will re word the question
Photo of Dennis
Dennis, Mobile Master
  • 201,104 Points 100k badge 2x thumb
Data leakage is always a risk. Like when you restart your phone,etc.
Your best bet is to take out your sim
Photo of Mats
Mats
@Tim, leakage can always be a problem and yes people have been charged even though they never intended on using it. You don't need any add ons for a phone to be able to roam in the states. If you don't want to roam, go in your network settings and change it from automatic to manual. Then set it to Koodo. This will ensure your phone can't roam. If you ever do want it to roam you have to set it back to automatic.
Photo of Dinh
Dinh, Mobile Master
  • 45,986 Points 20k badge 2x thumb
Yes, it will. However you should make sure you know the rate of the easyroam/pay per use rate before roaming in US. Otherwise, you might have some nasty surprise later.
That add-on is free and you won't be charged if you don't roam internationally.
Photo of Dennis
The best way not to get charged for roaming is to take your sim out of your phone
