International Roaming
  • Updated 10 months ago
Is there a comprehensive list of Partner Carriers available and what countries International Roaming is available to...or maybe a shorter list indicating what countries there is no partner agreement with? Traveling in Asia soon and Im not sure if Ill just pick up new sims where I'll be or bring my number with me...
Photo of Greggor58
Greggor58
  • 566 Points 500 badge 2x thumb
Posted 10 months ago
Photo of Robert
Robert, Mobile Master
  • 103,858 Points 100k badge 2x thumb
You should be good.
Excluded countries:
Alaska, Hawaii, Puerto Rico, U.S., U.S. Virgin Islands (covered by U.S. roaming add-ons)
Satellite (e.g. cruise ships, airplanes, offshore)
Try checking here...
Use the drop down to select the country and you'll see a list of roaming partners
Enjoy your trip
https://www.koodomobile.com/help/inte...
Photo of Greggor58
Greggor58
Cool...thanks Chad, Ill check it out...I couldnt find this...Good hunting!!
Photo of Greggor58
Greggor58
If the destination country isn't included on the list does that mean I'm out of luck...? I see Thailand...but no Philippines...
Photo of Greggor58
Greggor58
Disregard my last comment...I did find Philippines...thanks again Chad..thanks Robert!
Photo of BobTheElectrician
BobTheElectrician
  • 62,114 Points 50k badge 2x thumb
Alternative local suppliers and frequencies used. You should check out your phone frequencies first
http://prepaid-data-sim-card.wikia.com/wiki/Prepaid_SIM_with_data
http://www.worldtimezone.com/gsm.html
Photo of Robert
I'd go with a local SIM. Way cheaper then paying for roaming. This is what I do everytime!
Photo of Greggor58
Greggor58
Thanks Bob...thanks Robert...I normally swap out the SIM when Im in Asia with whatever-local Carrier offers the best deal... I was thinking perhaps this trip Id just keep and use my regular contact number...Im not sure...Ill figure it out...for sure it would probably be cheaper to do that than pay Koodo...
