International Long Distance Saver add-on
  • Updated 2 weeks ago
Hello. I added the International Long Distance Saver add-on last week. Yesterday, I've called to Colombia and you charged me 0.50 $ per minute instead of 0.5$. The add-on is not activated?
Photo of Mayra Gutierrez
Mayra Gutierrez
  • 92 Points 75 badge 2x thumb
  • Frustrated
Posted 2 weeks ago
Photo of Goran
Goran, Mobile Master
  • 97,868 Points 50k badge 2x thumb
Those two numbers are the same. I assume that you mean 5 cents per minute. Can you check in self-serve that it shows as added and let us know?
Mayra Gutierrez
Sorry. I wanted to say 0.05$... Yes, I can see it in my current plan: Your current plan
$45per month
  • Unlimited minutes
  • 2 GB of Shock-Free Data
  • Unlimited messaging
Expand
Change my plan
Add-ons
  • Pay-Per-Use Intl Long Distance$0.00
  • $12/day Easy Roam INTL$0.00
  • International Data Roaming$0.00
  • International Voice Roaming$0.00
  • $7/day US Easy Roam$0.00
Photo of Bernard
Bernard, Official Rep
  • 81,138 Points 50k badge 2x thumb
If you look at your invoice, you could see if you indeed added the feature Mayra. We would have also sent you a confirmation email if it was added. I don't see it on your account. :-(
Mayra Gutierrez
I did not receive an email to confirm but I can see it in my current plan
Photo of David
David, Mobile Master
  • 93,960 Points 50k badge 2x thumb
Is not the same as International Long Distance Saver $3.00.  Pay-Per-Use Intl Long Distance allows calls to be made outside the US and Canada (i.e. it removes blocks of calls to all other international area codes).  Your list does not seem to include the add-on you initially described.
Photo of Bernard
As per David above you may have misunderstood the different features. The one you need comes with a monthly fee of $3 in order to reduce the rates.
