Instead of a picture text, my phone gives me a link to a non-responsive web page for more MMS info.
  • 2
So I got a new phone - samsung Ace II. With the same plan as before. Which includes picture texts. However, when I try to send or receive a picture text, it tells me to go to koodomobile.com/bb for info on MMS. Except that page doesn't exsist apparently. How come pics worked on my old piece of shit phone? Any ideas how to make it work on this new one?
Photo of Emilie Billings
Emilie Billings
  • 2
Photo of Sophia
Sophia, Mobile Master
Congrats on your new phone :D Can you confirm that your MMS settings are correct as posted here, Emilie?
http://koodomobile.com/en/ab/non-kood...
Do you have data on your plan?
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,212 Points 100k badge 2x thumb
You will receive that message if you receive a picture message while data is disabled on your account. HSPA phones require an active data connection to send or receive pictures. This is the way the network is designed and has nothing to do with koodo. Older CDMA phones handled pictures differently and did not require an active data connection for picture messaging.
Photo of MatB
MatB
  • 32,458 Points 20k badge 2x thumb
On your post you said that you should go to "koodomobile.com/bb", which is a dead link, for me bb refers to Blackberry, did you have BB plan?
You will get that link on any phone that receives a picture message with data blocked, not just bb, regardless of what the link seems to indicate.
Photo of MatB
MatB
thank you Timo Good to know!
Photo of Hamilton Asseiro
Hamilton Asseiro
I had the old Blackberry 9230 phone...how do I get pictures with my text on it...I pay for both text and pictures...I can't get pictures from my friends...just shows a download box and I click on it and nothing happens!
Hamilton Asseiro
I was getting pics on the monthly plan but with my prepaid I get no pictures!
Emilie Billings
I don't have data. My MMS settings are set up as described above - I did read someone else's instructions on how to get around the dilemma described by Timo, and I created to new APN which should allow me to stll use picture messaging. But no dice. This is balls. I have a computer. I just wanted a phone to text with. And send the odd picture.
Photo of Get it solved !
Get it solved !
  • 4,044 Points 4k badge 2x thumb
At this point you have to check if the data is not blocked on the koodo side.
Login to your self serve account and check if there is a Block data add on.If so then just remove it .If you cannot get access to Self serve then call *611 from your mobile or 1-866-995-6636 from a landline
