Info about unlocked phones
  • Updated 2 years ago
I am already a Koodo customer.  I own a LG-A341 phone.  If I buy an unlocked Moto G (1st gen, XT1032), will my present simcard will do in the Moto G?  If not, how can I buy one?  How much will it cost?  Is there any other cost for bringing an unlocked phone I buy elsewhere?
Photo of Jérôme Leclerc
Jérôme Leclerc
Posted 2 years ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 202,946 Points 100k badge 2x thumb
I can't find what size SIM Card you have in your present phone but the Moto X 1st Gen takes a Micro SIM so if your present phone doesn't take a Micro SIM then you will need to buy a new one which is $5 if your on postpaid or $20 if your on prepaid.
If you have a Micro SIM in your present phone then take it out and pop it into the new ok hone and away you go, no extra costs.
Jérôme Leclerc
My old phone has a standard sim, not a micro.  Can I buy a sim card online, I can't find it
Photo of Anna
Anna
  • 6,126 Points 5k badge 2x thumb
Hey Jérôme! SIM cards are not available for purchase on our website. You can find them at any of the Koodo locations and most retailers http://koo.do/1YM8LhV :)
Photo of Chadwick
Chadwick, Mobile Master
  • 33,092 Points 20k badge 2x thumb
You can also cut the sim down yourself .If your somewhat handy with a exact-o blade, you will be fine. If your not comfortable you could get a micro sim.
  • 202,866 Points 100k badge 2x thumb
With an exacto yikes I wouldn't be using one of those to cut them, use a sharp pair of scissors if your going to do it, one slip with a blade and you could damage the contents of the card or worse cut your hand quite easily. You can find the pattern online to cut it if you choose to but I strongly recommend against cutting Sims because any sharp Edge can get caught in the SIM tray and break the pin connectors damaging the phone. I've seen it first hand more than once of this happening to ppl so it's definitely worth the couple bucks for a new one. Also the new ones are NFC enabled so if one of your phones in the future has the ability to make mobile payments your set.
Photo of Chadwick
Like I said. If your handy or comfortable with a knife you will be fine. Lol I've done more than 50 with a blade when I worked for one of the big 3. I found the scissors to cause bending and cracking where u don't want it. But if your using good scissors u should be fine. Most kiosks will have a SIM cutting tool so if your at a mall u could always ask
Photo of Chadwick
I can second the sharp edges ruining phones internals if u have jagged points. Seen it happen to a few people who use dull scissors.
Jérôme Leclerc
I had no problems cutting the sim card.  I searched on google for a good template (search: mini sim to micro sim template pdf), printed it at 100% for accurate measurements, then cut it with a x-acto(new blade).  You have to work carefully, but it can be done!
Photo of Chadwick
Awesome! glad you got it done and still have your fingers and a working SIM lol
Jérôme Leclerc
Thank you for the good answers!
