Incoming USA calls - is there a charge for that?
I have $30 CAN talk and text 100 minutes. While I am at home (Brampton) I receive a call from the USA. Will I be charged a long distance fee? Will the time spent on that call come out of my 100 minutes?
Photo of Susan Smith
Susan Smith
Posted 3 years ago
Photo of Sophia
Sophia, Mobile Master
No worries, Susan, as long as you in Canada, all incoming calls are treated equally :) But yes it will use up your regular air time.
Photo of Tynisha Ford
Tynisha Ford
  • 370 Points 250 badge 2x thumb
All your incoming calls are treated the same as long as your in Canada. You will use your minutes though. Unless your plan includes the free after 5pm and weekends. Which would then be the best time to receive calls if you don't want to use all your minutes.
Good luck hope this helps
