incoming does not ring
  • Updated 2 years ago
  • (Edited)
I have koodo self serve pay as you go.  When I call the number it does not ring although the call shows as incoming and I can answer it just fine.  The only problem is I cannot hear it.  Other apps like Magicjack ring fine.
Photo of johan
johan
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Dennis
Dennis, Mobile Master
  • 196,080 Points 100k badge 2x thumb
Go into your settings and see if you have Blocking mode enabled
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,506 Points 100k badge 2x thumb
Also make sure you haven't accidentally enabled do not disturb mode.
Photo of Melissa
Melissa, Employee
  • 11,748 Points 10k badge 2x thumb
Hey Johan, we had to edit your post since you included personal information (phone number). Is it working now? Can you make sure the sound is turned on? Keep us posted!
Photo of johan
johan
Thank you Melissa.  Yes I had blocking mode set.
