Incoming calls on LG5 go straight to voicemail
  • Updated 10 months ago
I got a new phone and ever since a few days ago all incoming calls are going straight to voicemail. I can send and receive texts fine and can make outgoing calls with no problem.
Any suggestions?
Photo of Joel
Joel
Posted 10 months ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Hi Joel, make sure your do lot disturb mode isn't turned on for calls or calls won't come through.
Photo of Joel
Joel
It's not - when someone calls it does not ring, nor does my phone show a call. It just goes right to my voice mail
Thanks
Are you in a place with spotty service, if you have no service when the person calls it will go straight to voicemail. Do you have solid reception where this is happening or only a bar or two
Photo of Joel
Joel
No this is at home and my office - I have never had problems with service there before, or really anywhere else.
Have you tried restarting your device?
Photo of Joel
Joel
yes a couple of times, I have a feeling I will need to take this in
Photo of Melissa
Melissa, Employee
  • 11,748 Points 10k badge 2x thumb
Hey Joel, did you port your number in? The issue that you are describing seems to be coming from a porting issue. If so, I suggest getting in touch with our customer service team and they will be more than happy to take a look at it. Thanks!
Photo of Joel
Joel
Not sure what you mean by porting, I have been a customer for a number of years now, I just got a new phone with the same number.
Photo of David
David, Mobile Master
  • 89,430 Points 50k badge 2x thumb
Did you move you old SIM card to your new phone, or did you have got activate a fresh SIM card?
