Incoming calls
  • 2
on the $33 monthly plan, are incoming calls part of the 300 minutes allowed or are all incoming calls free?
Photo of Jim Fleck
Jim Fleck
Posted 3 years ago
  • 2
Photo of Justin Robichaud
Justin Robichaud
  • 5,002 Points 5k badge 2x thumb
All incoming are free unless they come from outside Canada. Then they use your minutes I believe.
Photo of Jim Fleck
Jim Fleck
Thanks. Appreciate your help. Have a great day!
Justin Robichaud
You as well.
Photo of Mathieu Carrier
Mathieu Carrier
  • 4,124 Points 4k badge 2x thumb
Unfortunately that is false, Incoming and Outgoing both take your airtime. The only way it doesnt is if it specifies on the plan Free Incoming Calls, this is only on some very old plans. However, you are not charged for incoming Long Distance.
Photo of BobTheElectrician
BobTheElectrician
  • 67,174 Points 50k badge 2x thumb
All incoming calls gobble regular plan minutes, regardless of their origin. The only way to get "free" incoming or outgoing is to buy the appropriate "unlimited" add-on.
Long distance will apply to all OUTGOING calls that fall out of your normal calling zone.
Justin Robichaud
Thanks for the clarification! Can't believe I didn't know that.
Photo of Mathieu
Mathieu, Mobile Master
With the 33$ plan you do receive unlimited calls during evenings and weekends but any calls (incoming/outgoing) made during weekdays will be deducted from your 300 minutes.
