Incoming calls going straight to voicemail most of the time
  • Updated 2 years ago
I switched over from Rogers to Koodo around 2 months ago. Lately a lot of people have been telling me that calls are going to straight to voicemail but when they call back right away it rings. I have noticed as well that I see missed calls but the phone doesn't ring. At first I thought I didn't hear the sound but now that I have paid more attention I have noticed that it just shows I missed a call. I attempted to recreate the problem and I just called myself from my work line and it went straight to voicemail and it showed that I missed a call but my phone didn't ring. When I called the a second and third time my phone rang. I have an iphone 6s unlocked (bought from apple) and I never had this issue before on rogers. I had turned off the phone, removed the sim but it didn't seem to solve the problem. I don't believe its the phone was I was using the same phone with rogers. I have had Telus in the past the service was really good, however I have noticed that the Koodo signal strength is not as good as Telus. The number of bars are lower than expected. I had higher bars on rogers. Its usually 3 or less bars of signal strength wherever I am. My assumption was that it would be higher than rogers.
Photo of shamsa
shamsa
  • 82 Points 75 badge 2x thumb
Posted 2 years ago
Koodo = TELUS
Same network...Same carrier.
The only difference between Koodo and TELUS physically is what floor they are on in the same building.
What phone do you have?
Oops just noticed iPhone
Photo of Robert
Robert, Mobile Master
  • 106,774 Points 100k badge 2x thumb
Hello there.
Telus and Koodo are on the same network. Like literally the same towers. Laying less for a service doesn't mean you'll have lower coverage. That can't be the reason why it goes directly to voice-mail. I can take calls with my iPhone at 1 bar of signal.
Do you have ado not disturb mode activated? When you do, call usually go directly to voice-mail. The small half moon is what shows if you have do not disturb mode activated
Photo of Dennis
Dennis, Mobile Master
  • 196,004 Points 100k badge 2x thumb
Definitely sounds like Do Not Disturb is enabled if a second call rings
Photo of shamsa
shamsa
Omg you were right I did have it on, I didn't even notice. For some reason i thought the half moon was the night mode.
Check also the switch on the left side of the phone. It shouldn't have any red showing. If it does...flip it up.
