Incoming calls and minute usage
  • Updated 1 year ago
I have the $15 unlimited text/base plan plus additional booster talk minutes. Do incoming calls use up my minutes if I don't answer them? What about voicemails? I have been receiving nightly unsolicited calls and want to know if they are using up my minutes? Also is there any way to block these calls. Thanks.
Photo of Sandra
Sandra
Posted 1 year ago
Photo of Dennis
Dennis, Mobile Master
  • 187,512 Points 100k badge 2x thumb
If you dont answer then they dont use your talk boosters.
If missed calls go to voicemail, they dont use your talk boosters.
To call your voicemail on your cell phone will use talk boosters.  But if you call from another phone to retrieve your voicemail, it wont use any talk boosters.
Yes you can block calls from specific numbers in the settings of your phone app
Photo of Sandra
Sandra
Thanks for the information.☺
