In airplane mode, can my LED flash when I get a voicemail?
  • 2
I have an android Samsung Galaxy S3, and like to keep it in airplane mode ...the problem is that if someone calls and leaves a voicemail, I won't know about it until I turn the airplane mode off, which I may not do for days (as I'm not a frequent user of the phone, and this way preserves the battery power, and I don't get unsolicited calls!)
Photo of Jay N
Jay N
  • 486 Points 250 badge 2x thumb
  • 2
Photo of John Lee
John Lee
Unfortunately, I do not believe your LED will flash when you get voicemail when you have airplane mode on. Airplane mode disables all cellular connection so the device would not know that it has received a voicemail unless you put it turn airplane mode off.
