Immediately provide a replacement phone if a customer needs to repair their faulty phone. Give Kiosk staff authority to replace phones.
  • Idea
Immediately provide a replacement phone if a customer needs to repair their phone because of a faulty phone, not because of something the customer did. Give your kiosk staff the authority to replace faulty phones.
Photo of Leslie Stanick
Leslie Stanick
Photo of Iwona Pollard
Iwona Pollard
  • 60 Points
Yes I need to get a different one so they can check what the hell is wrong with mine cause I have a breach that I think =_= I brought from wind with me but this is to long and to crazy to write in a post but I hope ill find out who is behind all this but I do have an idea. Please can someone can tell me if I can do it myself?somone is operating my phone and gmail remotely and it is pissing me off cause my texts are missing my gps comes on when I did shut it off enough fore and I can't deal with this no more.,!!please help!!! :-)
Depending on your phone, you need to perform a full reset. You'll loose everything but it will bring the phone back to factory conditions.
Android: Settings > Backup and Reset > Factory Reset
Koodo Does offer loaner phones however when you bring in your "Faulty" phone Koodo has to send them to the manufacturer, who then makes the replace / repair decision. Koodo doesn't actually repair the phone. think of Koodo as the middle man between you and the manufacturer
