iMessage not working with data enabled.
My iMessage is not working while on data. It works on wifi just fine. My data does work for browsing though. I've turned imessage off and back on, reset the network settings etc but still nothing. Any suggestions?
Photo of kelly edgeley
kelly edgeley
  • 90 Points 75 badge 2x thumb
Photo of HippieLongstocking
HippieLongstocking
  • 24,720 Points 20k badge 2x thumb
best i got for ya is go into settings turn on send as sms and try ressetting the network settings again, if this fails hold down the power button and home button until the apple appears on the screen. :D
Photo of Dennis
Dennis, Mobile Master
  • 195,746 Points 100k badge 2x thumb
Settings>General>Reset>Reset Network Settings
kelly edgeley
Yeah I've done all those with no luck thus far. Thanks though!
Photo of Dennis
If imessage works on wifi and data works on browsing then imessage should work on data since imessage just needs an internet connection.
Are you messaging people with imessage on? What is being displayed then imessage fails?
kelly edgeley
Yup that is the problem. Something with data is not working.
I just get a red, delivery failed and then it sends as a text. But I'm not getting replies because people are responding with an imessage and it says delivered on their end.
Photo of Dennis
The fact that it works on wifi will rule out any issues on Apple's end.
I'm out of ideas if you tried everything teabird suggested.
At this point I would do a back via itunes and a full factory reset
