i'm unable to make long distance calls it say call cancelled.
  • Doesn't Need an Answer
Photo of Samantha Wilson-Macdonald
Photo of Jonathan I
Jonathan I, Mobile Master
Only LD calls but local still works? That's odd. No matter if it's LD or not, a failed call is a failed call. Are you putting a 1 in front of the #?
Try putting your phone in airplane mode for a minute and then turn it off again. If that fails, remove the battery (if possible) and SIM card for a minute and try again.
