I'm wanting to switch from Rogers to Koodo, but my phone from Rogers still has a balance on it.
  • Updated 3 months ago
I'm wanting to switch from Rogers to Koodo, but my phone from Rogers still has a balance on it. Am I still able to switch, or do I have to wait until my balance is zero? I'm not able to buy it out at this time.
Photo of Afton Leah
Afton Leah
  • 114 Points 100 badge 2x thumb
Posted 3 months ago
Photo of Dennis
Dennis, Mobile Master
  • 196,890 Points 100k badge 2x thumb
You can still switch. Rogers will send you a final bill which you will be responsible for.
Note that when you switch to Koodo and sign up, they will run a credit check
Photo of Afton Leah
Afton Leah
thanks. out of curiosity, is it a hard or soft check? sorry, i've been with rogers since the earth was cooling. it's been a while since I've done this.
Photo of Dennis
I believe it's a soft check, but I'm not certain.
If your credit is not good enough, they may place you on a spending limit program
Photo of Afton Leah
Afton Leah
thanks for the info! i appreciate it :)
Photo of TJ Smith
TJ Smith
  • 4,502 Points 4k badge 2x thumb
I can confirm that it's a "soft check". Just make sure you pay Rogers once they send you the last invoice after you port your line to Koodo.
Your Account# from Rogers is all Koodo needs to grab the number from the other side.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,958 Points 100k badge 2x thumb
If you pass the credit charcoal and the phone is unlocked and compatible with Koodo's frequencies then you can switch. If you don't pay your balance with Rogers through Rogers may blacklist the phone and it will become useless on anything but wifi
