im not receiving incoming calls in my nexus 5
Photo of rafael V.S. roman
rafael V.S. roman
Photo of Sophia
Sophia, Mobile Master
Did anybody try to call you? I'm joking but Rafael many things could be wrong, we need some more information. Did you enable redirect perhaps, or direct calls straight to voicemail? What message do people get when they call you? Can you call out? Have you ported your number recently?
Photo of Jason Smith
Jason Smith
  • 1,020 Points 1k badge 2x thumb
I would reboot the phone first. And also see if it is more than one person trying to call you. It could be the other end but if it`s more than one person calling you, then it would be on your end.
A factory data reset usually fixes almost all problems.
Good luck.
Photo of iOS Cam
iOS Cam
  • 346 Points 250 badge 2x thumb
Also check if your Phone has accidentally blocked certain numbers, i've seen it happen before its just a small mistake but it can cause a bunch of problems
