I'm not able to send international texts or make calls from Spain. I can receive texts and data works.
  • Updated 1 year ago
I'm not able to send international texts or make calls from Spain. I can receive texts and data works. I have both voice and data roaming monthly add-ons activated. I have also tried removing the SIM card and toggling the airplane mode to reset the connection. I am using an iPhone 5s. Any ideas?
Photo of Kurtis Schram
Kurtis Schram
Posted 1 year ago
Photo of Goran
Goran, Mobile Master
  • 90,032 Points 50k badge 2x thumb
Give a different texting app a shot. Are you doing +[country code] when you text or call?
Kurtis Schram
Yes, I am using the +[country code]. I tried entering the numbers manually instead of using contacts to be sure.
Photo of Josie
Josie, Employee
  • 3,248 Points 3k badge 2x thumb
Hey Kurtis, let's give this another shot to refresh settings: set your phone in airplane mode for about 15 seconds.  Please get back to us and let us know if it works
Kurtis Schram
Thanks Josie, it is working now. Did you change something on your end?
Photo of Josie
Josie, Employee
Great stuff!!  Thought it'd be worth a try to refresh on our end but think it was another attempt to reset that kicked it in so to speak.  Enjoy Spain!
Photo of Goran
Can you see which network you're connected to for roaming? And if you have the network selection to connect to any type of network?
