I'm looking for roaming for international
  • Updated 3 months ago
Photo of Scamp Cooke
Scamp Cooke
  • 222 Points 100 badge 2x thumb
Posted 3 months ago
Photo of Goran
Goran, Mobile Master
  • 96,868 Points 50k badge 2x thumb
You have pay per use rate options and easy Roam, which let's you use your plan as normal for 10 dollars a day up to 100 dollars per billing cycle. Depending where you are and your usage, it could also make more sense to get a data sim for cheap where you go. You can add easy Roam in self-serve as well as international voice and data roaming add-ons which are free add-ons that enable international roaming.
Photo of Dennis
Dennis, Mobile Master
  • 195,890 Points 100k badge 2x thumb
You can find easy roam details here
https://www.koodomobile.com/help/easy...
