I'm looking at Koodo wireless home phone. Can I connect more then one handset to the Koodo hub?
  • Updated 1 year ago
Photo of Rick
Rick
  • 80 Points 75 badge 2x thumb
Posted 1 year ago
Photo of David
David, Mobile Master
  • 88,974 Points 50k badge 2x thumb
There are two output jacks on the device. Most folks just attach a multi-handset cordless phone base to the WHP device, and scatter as many other handsets around the house as they need.
Photo of Rick
Rick
Thanks David.
Photo of titaniumtux
titaniumtux
  • 12,912 Points 10k badge 2x thumb
You could get a telephone jack adapter to connect multiple telephone wires into a single output jack. You could get telephone wiring kits at the hardware store. The sky's the limit. However, if you're planning on using existing wiring in your home, make sure the wiring doesn't touch the old POTS demarcation point, as it may carry voltage, and toast your adatper.
Photo of Dave Phillips
Dave Phillips
Just make sure to disconnect your current home wiring from Bell or who ever you were getting home phone service from and your good to go.I have done it in several home's with no problems.
