I'm in Mexico and cannot text a code to koodo, it wont allow me to chang my pLan in self serve. What can I do to get roaming?
  • Updated 1 year ago
Photo of nadine
nadine
Posted 1 year ago
Photo of Goran
Goran, Mobile Master
  • 97,238 Points 50k badge 2x thumb
Try the self-serve app. Make sure you also add international voice roaming. Data requires international data roaming. Personally I suggest getting a local prepaid Sim card with AT&T Mexico as they currently seem to have the best rates. Certainly much better than the roaming rates Koodo offers. If you need a Canadian number, download Fongo or Textnow and you can get a number for free that you can use with a data connection.
Photo of Bernard
Bernard, Official Rep
  • 80,862 Points 50k badge 2x thumb
Do you have coverage where you are Nadine? Your account has the free roaming add-on to enable you to use the phone. You last logged into your online account 4 days ago, is that when you were unable to change your plan?
You will still need one of the international roaming add-ons to to take advantage of lower rates.
Photo of Allan
Allan, Mobile Master
  • 62,392 Points 50k badge 2x thumb
You can login to self serve online as well and add all the appropriate add ons that way.
Photo of Bernard
Just a heads up Allan, roaming add-ons can only texted or added via the Koodo app. Not online.
Photo of Allan
Ahh yes, i was just referring to the international add on, not the voice and data roaming. Thanks!
Photo of Dennis
Dennis, Mobile Master
  • 196,120 Points 100k badge 2x thumb
Bernard,
Why can roaming add-ons be added to the app but not online via self serve?  It would be a good idea for both platforms to do both
