I'm having trouble recieving long distance calls from US
  • Updated 2 years ago
incoming calls from US are not coming in
Photo of Heather Warren
Heather Warren
  • 90 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Robert
Robert, Mobile Master
  • 107,280 Points 100k badge 2x thumb
Hello Heather.
Why are you so sure they are not coming in? I find it difficult to believe that normal call are coming in but the one from the US aren't?
Photo of Goran
Goran, Mobile Master
  • 97,462 Points 50k badge 2x thumb
Can you double check that the people calling you have the right number and are dialing 1 then your number? There is no + or 00 or whatever needed as Canada and the US share the same country code and numbering plan.
Heather Warren
I talk to my sister almost daily, and she appeared to be not answering, so I facebooked her, she was answering but I'm not getting them. We ran several tests, no answer. I have checked that everything is correct with my phone as has she.
Photo of Alaa
Alaa, Employee
  • 918 Points 500 badge 2x thumb
Hi Heather,
Do you experience the same thing with calls from different numbers, different carriers ? Are you receiving calls without any problem ?
Keep us posted !
Heather Warren
I only call that one US number. I have no trouble with my other numbers
Photo of Melissa
Melissa, Employee
  • 11,748 Points 10k badge 2x thumb
If I understand correctly, you are able to call her but she is not able to call you? If the issue is only her not being able to call you she should contact her service provider to check out if there is an issue on their end.  Let us know!
