I'm cruising to hawaii. will there be extra roaming charges at sea?
  • Updated 2 years ago
  • (Edited)
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: roaming add-on
samsung android phone with canada wide plan sailing from vancouver to hawaii. will the temporary add-on roaming feature be enough?
Photo of David Small
David Small
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of David
David, Mobile Master
  • 89,300 Points 50k badge 2x thumb
There are no roaming packages for shipboard roaming. You will pay their extortionate per minute rates until you get to Hawaii where any US roaming package that meets your needs will work.
I suggest planning for other means to connect with your loved ones, and others while you are at sea.
David Small
thanks!
