If there is no long distance why do we have to dial 1-709 (which means long distance) to reach a Koodo #
It is even Long distance for Local #'s to call my Koodo #
Photo of Trudy Keeping
Trudy Keeping
Photo of Daniel Gunn
Daniel Gunn
  • 19,800 Points 10k badge 2x thumb
It could be picking up signal from a separate tower on the network or it could be how the network is registering where you're calling to. The only thing long distance is going to do is use your anytime minutes if you don't have an unlimited plan.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 137,052 Points 100k badge 2x thumb
A Canada wide plan does not mean there is no such thing as a long distance call, it just means that you don't get charged extra for them.
Photo of Jonathan I
Jonathan I, Mobile Master
I think what you might be hearing is the automatic voice that says "Long distance charges may apply" because the phone system can't decipher what your plan is like or who your carrier is. Since your plan is Canada-wide, they don't actually charge you for it.
Photo of Jru Gordon
Jru Gordon
  • 9,018 Points 5k badge 2x thumb
on a side note, with Virgin, it still says "long distance charges will be applied" even though they won't. That causes more headaches for people
