If I've only had my prepaid phone for under 2 weeks and it's screen has shattered, would I be able to get it replaced? :c
I've only been with Koodo for under 2 weeks with this phone and it shattered from falling off my bed! Would they cover getting the screen fixed? The LCD is fine, it's just that the screen is screwed. The phone was a used phone so I dunno.
Photo of Racquel Watson-Fleming
  • 203,644 Points 100k badge 2x thumb
Unfortunately no, a broken screen is considered physical damage and is not cover under the manufacturer warranty.
Aw :c thanks for answering though~
Photo of Ivan
Ivan, Mobile Master
  • 95,532 Points 50k badge 2x thumb
I'd recommend going to your local repair shop for non-warranty fixes. They'll be a lot cheaper. Screen repair is anywhere from $50 to $250, depending on phone.
