if im using wifi with my phone do I need to turn on data enable?
Photo of Evelyn Kelly-Post
Evelyn Kelly-Post
  • 312 Points 250 badge 2x thumb
Photo of Erwin
Erwin
  • 23,546 Points 20k badge 2x thumb
Hi Evelyn,
When you connect to a wifi connection, your data will automatically be disabled. So there is no need to manually turn off your data when you are connected to wifi.
Photo of Myke
Myke
Mobile data is not "disabled" when wifi is on. You can have Mobile data on & Wifi on at the same time, however the phone will use the Wifi connection over the Mobile data connection
Photo of Erwin
Erwin
Yeah, wifi is on data is still there but is not being used.
Photo of Myke
Myke
Right, not being used is different from being disabled.
Photo of John Lee
John Lee
Myke is right. Data is not "disabled", it's just that when you have WiFi on and Data on and you have Wifi connected, it will choose to use WiFi over your data. However, if somehow your WiFi connection fails (which happens frequently), it'll automatically transfer to your data connection.
Sometimes when you're watching a youtube video, you can't see the very top bar so sometimes people mistakenly watch a video with WiFi but mid-way, the WiFi connection got lost and it started using data.
So it's just a precaution :)
Evelyn Kelly-Post
then why cant I use internet when it says im connected to my wifi??
when I go to settings....wifi it says connected but when I open playstore it says no connection??
Photo of Myke
Myke
Keep in mind, Koodo CANNOT troubleshoot your wifi issues. Any issues pertaining to your wifi connection, no matter which device, you would need to contact your ISP.
Evelyn Kelly-Post
tried this didn't work!...don't want to turn data on b/c ive already been charged for data I didn't realize I was using!
Photo of Myke
Myke
Unless you are trying to do picture messaging, you do not need to have Mobile Data turned on. Call your ISP for your wifi issue.
Evelyn Kelly-Post
ok, thanks for your help!
Photo of Mayumi
Mayumi, Mobile Master
  • 112,838 Points 100k badge 2x thumb
If you are using a public wifi connection, you can be connected to wifi but not signed into it, To check that you are connected, go to your internet icon and usually you will be re-directed to a sign in wall.
