If I use LTE instead of 3G will it use my data faster?
Photo of HootSuite App
HootSuite App
  • 1,100 Points 1k badge 2x thumb
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,496 Points 100k badge 2x thumb
you'll use the same amount of data for everything you load.
Photo of Robert
Robert, Mobile Master
  • 106,774 Points 100k badge 2x thumb
It will inded load faster but your battery life will drain faster too!
Photo of Dennis
Dennis, Mobile Master
  • 196,006 Points 100k badge 2x thumb
If you load things faster it means you can view more webpages in the same amount of time which usually translates into you doing more data usage
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,250 Points 100k badge 2x thumb
That and also if you accidentally load pages ect then more data will be used before you catch the error since things are loading much quicker ;-)
I usually leave LTE off to conserve the battery. Unless you're streaming media it's really not necessary.
Photo of Dennis
Except battery life seems to be better on LTE for the iphone 5s
http://www.apple.com/ca/iphone-5s/specs/
