If I buy a Telus phone and put a Koodo sims card in it, will it automaticaly activate since Koodo is a branche of Telus?
  • 4
  • Updated 1 month ago
I just bought a Samsung Galaxy 3 from a friend but it's a Telus phone and I wunder if I put a new sims card from Koodo if it would activate since it's not with the same company...
Photo of Vanessa Mapp
Vanessa Mapp
  • 4
Photo of Camilo_A
Camilo_A
  • 31,012 Points 20k badge 2x thumb
Hi Vanessa... Your phone most likely will work with a Koodo Sim Card without the need of unlocking the phone.... All you need is an active Koodo Sim and you are good to go...
Vanessa Mapp
Great thank you !!!
Photo of Dave Crombie
Dave Crombie
  • 152 Points 100 badge 2x thumb
That was true for me, too
Photo of Alex
Alex
  • 320 Points 250 badge 2x thumb
Not all Telus phones are unlocked, nobody can confirm exactly which model is unlocked to work with Koodo. But you can go in a Koodo store to test it with a koodo sim. Its the same way for koodo phones. Except for Iphone and LG Nexus.
Photo of Ivan
Ivan, Mobile Master
  • 96,292 Points 50k badge 2x thumb
Only the Nexus line is unlocked and can work with any other carrier without an unlock code.
All other phones are locked, but should still work with Koodo. This is because both Telus and Koodo use the same MCC-MNC (Mobile Country Code - Mobile Network Code), which is 302-220. The SIM restriction checks the MCC-MNC of the inserted SIM card and will not register on the network in case of mismatch. This is when you get a message that your phone is locked.
Photo of Nate
Nate
  • 150 Points 100 badge 2x thumb
It probably will my rogers phone works with chatr and chatr is owner by rogers
Photo of Jordan Vergette
Jordan Vergette
  • 60 Points
my telus iphone worked with koodo sim card-should be fine.
Photo of Arwen Smith
Arwen Smith
  • 60 Points
I talked to someone with telus and koodo and they both said that you do not need to unlock a phone to use either sim card
Photo of Robert
Robert, Mobile Master
  • 102,848 Points 100k badge 2x thumb
That's right. Koodo, public mobile and Telus can share phone between their networks!
Photo of Mark Kokolsky
Mark Kokolsky
  • 10,722 Points 10k badge 2x thumb
Its not quite that simple. It is true you shouldnt need to unlock the Telus S3, but you will most likely need to go into the settings and change the APN settings to the Koodo ones. Otherwise you wont get any data services on your S3.
This link will have information on where to look and how to change the settings. As well as what you need to change the settings to.
http://koodomobile.com/en/on/switch2k...
Photo of Andres Corrales
Andres Corrales
  • 304 Points 250 badge 2x thumb
If its not unlocked it costs like $15 to unlock it online
Photo of Stephen Kawamoto
Stephen Kawamoto
  • 94 Points 75 badge 2x thumb
Not anymore thanks to the crtc.
Photo of Goran
Goran, Mobile Master
  • 85,226 Points 50k badge 2x thumb
This thread is 5 years old. It clearly no longer applies. Please don't revive an old thread. There's also many about unlocking being free now
Photo of happy....
happy....
  • 798 Points 500 badge 2x thumb
Samsung Galaxy S3 Telus needs NO unlock.I'm using it without unlock.
It works right away BUT you have to set up Koodo APN by manually to use Data service.
Photo of John Lee
John Lee
Most of Telus phones, you won't have to unlock or change their APN to work with Koodo. Some you have to unlock, some you have to change their APN, etc. I would go to your nearest Koodo store and pop a Koodo SIM card in and see for yourself first.
Photo of Ryan Peatt
Ryan Peatt
  • 90 Points 75 badge 2x thumb
I bought a telus lumia 520 and have it working on the Koodo network.
I did not need to unlock it, but I did need to change the APN settings.
For some reason I can only get 3G as an available connection option - I expected to be able to get H+. What am I doing wrong?
If I just want to text, same scenario, koodo card to old telus phone should it work?
Photo of heidi.pacheco
heidi.pacheco
  • 60 Points
What if the telus phone was reported as lost will it still work with Koodo
Photo of Tara Rose
Tara Rose
So telus I phones won't work with koodo?
Photo of Caper800
Caper800
  • 272 Points 250 badge 2x thumb
I was with Telus, switched to Koodo bringing over my iPhone 4 and had no issues at all. I did not have to get the phone unlocked. I just went to Walmart and had them do it. Only cost $10 for the SIM and I was on my way.
Photo of Cody Williams
Cody Williams
I have a Telus branded Samsung Galaxy Mega. A koodo sim does not work with it. Upon starting, it says "unregistered sim" so, in my case, I will have to unlock. Most phones you don't, some you do.
Photo of Jack Yonge
Jack Yonge
  • 2,350 Points 2k badge 2x thumb
unregistered SIM does not necessarily mean its locked.  It likely means that the SIM has not been activated.
Koodo and Telus have the same MNC, so there is no lock.  There is an exception where the phone may have the Telus APN setting hard coded, as is the case with the Samsung Note 1.
Photo of Valerie Brake
Valerie Brake
  • 60 Points
Meaning, we can set up a Telus Iphone with an Koodo Iphone ?
Photo of Goran
  • 88,324 Points 50k badge 2x thumb
I assume that you mean a Telus Iphone with Koodo's network? If so, then yes, and vice versa.
Photo of titaniumtux
titaniumtux
  • 12,912 Points 10k badge 2x thumb
@Paige by Samsung Note 11, you mean the Note 2? In that case, agreed with Chad. If you're referring to an 11" Samsung tablet, then Koodo might not be a first choice given that Koodo doesn't offer data only "tablet plans" to my knowledge (most other carriers offer data-only, tablet plans).
Photo of Jessie Jackson
Jessie Jackson
  • 60 Points
I have a lg g3 that is with koodo and it wont allow either a koodo chip or a telus chip to work in it. It doesnt say its locked it just wont connect to service
Photo of Sophia
Sophia, Mobile Master
  • 141,408 Points 100k badge 2x thumb
Can you start a new thread please Jessie? This one is 4 years old so would be easier to troubleshoot if you create your own. Thanks! :)
