if i block texting from another cell what shows up on their phone when they try to text me
Photo of Peter Redman
Peter Redman
  • 80 Points 75 badge 2x thumb
Photo of Robert
Robert, Mobile Master
  • 106,774 Points 100k badge 2x thumb
I guess nothing. They will just never receive your answer.
Peter Redman
So they see it as delivered. They do not get some message saying that I have blocked them?.
Photo of Robert
I don't think so. I usually don't ask myself this questions and never had to use this service. Some time or another, they will know that either 1) You blocked them or 2) You ignore them
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,496 Points 100k badge 2x thumb
Look at it this way: the only way to block texts from a given number is by using an app on your phone. The phone does not know what number a text is from until it is received. Most sms blocking apps do so by scanning the number an incoming text is from and then deciding to either pass it on or delete it automatically based on your blocked list. The message has still technically been delivered to your phone.
